Camry oil leak
5sfe oil leak from cam sensor area.is it a big job to repair.i have replaced the cam cover gasket.
thanks Harry Bowers |
Year of car?
Do you mean the timing cover seal? Make sure the oil pump driveshaft seal is not what is leaking. Look for oil coming out the bottom or firewall side of timing cover below the side bulge in the cover. |
