Can 2UR-GSE V8 (IS-F Engine) + Drivetrain Fit 2011 Camry SE
I have a 2011 Camry SE that I'm keeping forever. Basically the goal is turn this car into the ultimate sleeper. The 2UR-GSE is the V8 that is used in the Lexus IS-F and RC-F. Could this engine + drive train fit my Camry?
3 Attachment(s)
images on that motor shows up.. as a rear wheel drive set up ?
out of a lexus ? the v8 motor without a gearbox sitting in a lexus engine bay 2011 camry engine bay |
Anything is possible. However this would be a LOT of work if even possible.
If you want more HP, then investigate increasing the current engines HP. |
2 Attachment(s)
one obvious body modification required
the shock towers of the camry chassis have to come forward camry chassis extended forward heaps moulds and fabricate fiberglass front panels from windscreen gearbox selection limited if one intends east west set up for that v8 motor |
