Glenn8963 |
07-18-2010 05:08 PM |
if you are unable to reach from the top........well, you'll have to reach from the bottom. this is going to be a pain in the @zz because you'll have no leverage while playing on your back. a lift would be good for this, so you can stand up and work. i would also buy a new set of plug wires, because you are going to break them. also, be sure to buy a tube of "die-electric" compound. its "grease" of sorts that you put into the spark plug boots, to make the next replacement easier. now typically, number one cylinder is the cylinder, when you look at the engine, is "pushed" forward a bit from the other cylinder head. in other words, looks closer to the engine pulleys, and the other head is slightly pushed back from the pulleys.
