compression, in general
RE: compression, in general
Lower compression alone is not enough to call the junk man. A larger issue is oil consumption and engine power. Unless the engine has a head gasket leak or other problems would not be too concerned with compression.
A better test is a leak down test. Air under pressure injected into the cylinder and compared to what is leaking out via a pressure differance readout.
