Cruising RPM
New member and Toyota owner. When cruising down the interstate, O/D on and at 70mph the RPM's are at or just under 3k. Is that normal?
When driving turn the O/D off and determine if the RPM rises. If so O/D it appears to be working.
If the trans shifted through 1, 2, 3 and O/D is working, then the RPM should be normal. |
