Deciding wheather or not to put Intake.
I just got a 2003 camry V6 off the dealer lot and was wondering if anyone could suggest what to do without screwing up the emissions . i just want to take that big plastic box off and get an aftermarket cone. Any advice ?
RE: Deciding wheather or not to put Intake.
As long as you keep all the sensors in place such as air intake temp you will not effect emissions.
Adding a cold air intake may add a few HP but most likely you will never notice the differance. K&N makes these kinds of things, a websearch should turn up several vendors for there products. |
I have a cold air intake on my 05 Camry it has not given me any problems. But I would not recommend installing on because I have to worry about hydro locking my engine when ever it rains. If I were to do it again I would get the TRD or K&N square replacement filter or a K&N short ram intake. The only differenct that I can find between stock and myCAI is the soundI can notfeel any hp difference.
Nathan |
yeah i want to go just the intake part just do i can get rid of the plastic air box .
Ok well I would do a short ram intake. Do not just cut the box off and throw on a cone filter. But I still think that a replacement K&N of TRD filter would be the best choice because it does flow better but there are not any problems associated with it. Nathan
ok ill look into getting one then thank nathan . what about exhaust then ?
Well I have a borla exhaust and it works fine but there are many other good brands too. If I get extra time this weekend I will post a video so you can hear it. I picked borla because I have used it on my other cars and enjoy the sound.
Nathan |
sweet cant wait to hear it
Hey I just posted the video of the exhaust check it out it is under sights and sounds
Nathan |
