Does anyone have a suggestion?
I have a 96 Camry that has trouble starting after it has warmed up. I have been told that I was flooding it, But I don't give it gas when i start it. I was told it was a blocked fuel filter but when I pulled the old one off it was clear as a bell. I was told that the intake air filter was dirty but I replaced it and no difference.
Anyway if any one has an idea please feel free to chime in. |
RE: Does anyone have a suggestion?
Hi Plee...I looked on the internet to help you get you question answered, and this is what I found:
"The mos common warm stalls in camrys are due to one of the three following causes: 1 dirty EGR valve 2 dirty Idle control valve 3 defective Engine coolant temp sensor (erratic and tricky to pin point on syntoms) I would venture that your stall/hard to start after car is warmed up, is cause by the ECT. I just would change it, very simple job, unscreew the old one and install the new one (wiyh a little of tefon in te thread), no need to flush the coolant. If you have your car warm, stop for a few minutes and then it cranks but does not run, disconnect the ect senso and try ot start it again. If it does start, there is a very good chance that is the ECT sensor. This is just a test, never drive witrh the ECT sensor disconnected." This was posted by a user named "burchard" on http://www.automotivehelper.com/topic615013.htm. I wish you the best of luck and let me know if I can help you find anything else. |
