Help help help
well i know the 5sfe and the 3sfe can be swapped pretty easily due to them having the same engine mounts. and i know that the 5sfe and 3sgte also uses the same mounts. so im 90% sure that the 3sgte will bolt up just fine. as for shift linkages and axels do you know off the top of your head what tranny you have?
no. i have no idea..
its a 1989 3S-FE camry. if that helps..
i can order a 3S-GTE form jdmsource.com for 1500.
i just dont know what is interchangeable between cars, such as the axles, shift linkages, harnesses, etc.
