how to adjust idle on 1992 camry 4 cylinder?
my idle seems to have slowly but surely over the years.
the idle used to be around 600-700rpm when properly warmed up. now it never sees less then 1100rpm after warmed up. i looked in the throttle body and engine bay and no adjustment screw. anyone know how to adjust it down? camry 1992 auto 4 cylinder |
RE: how to adjust idle on 1992 camry 4 cylinder?
the adjustment screw should be near the throttle cam with a rubber plug cover....someone correct me if i'm wrong..it been awhile since i worked on a 94..
I can look into that later today, maybe tomorrow. My 94 4cyl is havin idle issues too, only mine isnt high its dropping to zero. It would still be nice to check out, see if any tweaking will help.
