Japanese 2.4 engine v.s. North American 2.4 engine
Hello, checking to see if anyone knows if the Japanese version of the 2azfe 2.4 L has had the same issues as the North American 2azfe 2.4L engine has? As far as oil consumption and head gasket failure? Looking to buy a engine from Japan because my 02 camry LE is buring through oil fast with 125k on it. Thanks!
Might check at the Toyotanation.com website.
I know this was a couple years ago, but did you ever find out if the swap is compatible? I am currently having the same question.
Never did the swap. Got rid of the car. I don't think the swap would be an issue. I was checking to see if the Japan model burned oil like the American model. From what I learned...they did burn too. Hope this helps.
Might inquire if Toyota improved the engine to eliminate the problems. Toyota's service bulletins about the oil burning reference a vehicle model and year range not all years and models.
