My Camry does not run well in high humidity!
My 1998 Camry's 4-cylinder engine does not run well in high humidity.
It sputters and will not accelerate. It takes a long period of warming before it runs well. What might be the problem? Thank you for your help. |
1 Attachment(s)
my thoughts
maf is the part that has the atmospheric /barometric sensors built it give maf a clean and its plug contacts of corrosion 2017 Wholesale New Mass Air Flow Sensor Meter Maf For Toyota 4runner Tacoma Camry Corolla 1998 2008 From Atuomoto, $34.04 | Dhgate.Com clean or replace the air filter if no better make sure the 02 sensors are ok |
Where is the MAF located?
Does it run poorly after a cold start as in sitting over night?
Does it eventually run well when the engine gets hot. Perhaps then running well until it sits over night? |
It runs poorly after a cold start after sitting over night.
After it warms, up it runs fine. |
Moisture could be causing issues.
Check the ignition system coils and high tension wires. You could use a hair dryer to heat the ign system components, sensors, etc one at a time to simulate a warm engine condition. |
