need camry faqs
hey, whats up every one, i'm a new user. i have a 2001 camry 4 cyl ce. just wondering what are some fags about theses cars. what goes first. on them, engine wise. i have have a valve cover leak. i dont see any valve cover bolts on the front visible, lol. never seen that before. it has a 123,000 miles on it. is there anything else i should check out in replacing with this amount of miles on it. thanks.
RE: need camry faqs
since you just got the car replace the seals where the leaks are coming from. and if your not familiar with its history you might as well change the timing belts.
RE: need camry faqs
i've had the car for four years, well it's my moms car. i have a crysler. just tryin to fix her car up for her. but i plan on changing the timing belt. are the timing belt and the water pump interface. does the water pump run off the timing belt on these cars. on my crhysler it did. so i just changed both.
