Timing belt sprockets
Hello All,
I have a 2005 Camry LE (3.0) that I am replacing the timing belt, idler, tensioner and pulley, water pump, seals and associated gaskets. This will be the third belt as the mileage is approaching 160K.
Is it recommended to replace the camshaft sprocket also? I'm pre-ordering parts and haven't disassembled the engine so I haven't laid eyes on this sprocket yet. Just wondering if that is a part that typically wears enough to require periodic replacement, as a matter of normal preventative maintenance, when replacing the timing belt.
Thanks
Thanks
Thanks for the response Joey....This one is fine I'm sure but I suppose it could get damaged when/if the seal behind it is replaced....I have that seal on my list just in case the old one is leaking....then again might replace it regardless.
boogz
Oct 10, 2007 07:55 PM
