Transmission modulator valve
Greetings All -
Can I kindly ask if anyone here might have an engine schematic &/or diagram on a '05 Camry XLE 3.0 V6 (1MZ-FE) ? I keep reading that the tranny modulator valve is mounted on the manifold and connects to the tranny with a vacuum hose. My issue is, I can not locate it. There are valves mounted everywhere in the engine compartment. I've inspected the manifold observing numerous gadgets on it. |
The trans does not have an external modulator as did older model trans nor perhaps even a modulator as such.
