Turbo for a 2.2l ?
Hey whats up am looking for a turbo kit for my camry does anyone know where I can find a kit for it on the Internet?I was looking for a motoor swap but I don't know if I can put an mr2 in my camry. Any advice?
Did not think the MR2 system would fit on an 5S-FE when installed in a Camry.
Ebay sells turbo kits but the qualilty for Camry appears questionable but those in the know. Years ago Bob Bridge Toyota in Washington sold a complete kit but not sure about today. Website below. www.1sttoyotaparts.com Suggest you do some reserch at Toyotanation and Google. Turbo 4 cylinder conversions are kind of common, enough that a lot of info is out there. |
e153 transmission. 3s-gte turbo manifold (off of the celica, direct bolt on) then you can use tha same turbo off of the mr2/celica or there's an adaptor out there that will let you use the garret t3/t4 hybrid turbo off of the supra. You've also gotta build the internals, replace all kinds of fuel and oil parts and your electronics system. I've heard of people putting the kit together for under 1000, but forged pistons and connecting rods are 750 (crank is already forged) and the parts to self installan e153 with an 2s53 pressure plate (only way it works) will run you about 2000. So if you don't have a manual, just buy a 3s-gte celica and put the 5s-fe block on it (direct fit except some minor mods to the coolant lines in the head) and it fly like a bat out of hell.
