Ultimate Sleeper
I recently inherited a 92 Camry LE and I've been talking to a few friends about what I can do to it. After a few months of thought, I finally decided to start a project: "Ultimate Sleeper"... without knowing the first thing about modding cars. After doing a bit of research, and a thorough inspection of the car, I've realized that I'll pretty much need to replace everything but the body. I have no idea where to start though, and would really appreciate any suggestions on what to do first.
Here is a list of things that work: (a lot shorter than a list of broken parts) A/C compressor Power steering Power brakes All lighting interior and exterior And the sound system/radio which has previously been upgraded before I got it |
Are you up to the effort and expense?
The 4-cyl is not known for HP but can add a turbo. |
I'm always up for the effort and the expenses don't worry me. Plus it's not like I don't have another car while I'm working this one.
The engine block has a crack in it, so I'm just looking for the meanest engine that can fit inside it. |
Might look into to a 5SGTE engine. Don't think it was ever used in an automatic trans car thus no ECU for auto and may need a stick. This swap will require work.
The 1MZ-FE engine/trans is a bolt-in option as it was an option. This engine is more favorable to modification. If going this route find a totaled donor car to be able to swap parts, as a lot of parts will need to be swapped. The 4-cylinder auto trans may not hold up to a lot of HP. |
The trans is pretty much dead, so it's getting replaced anyway. The previous owner never changed the fluid and it now looks like there's black metallic paint inside.
I'm sure I can find an engine with an appropriate trans attached though, the only problem would be finding that specific engine for a decent price. Thanks for the tip. Honestly, this project is going to take a while. Everything leaks and is on the verge of breaking. I don't even know how its still running. |
