Variable Valve Timing Gear
Does anyone else have a probably when you cold start your vehicle in the morning you motor sounds like it does when you first get you oil changed and it rattles really bad. That's what mine sounds like every time i crank my car cold. I was told it was that little gear. Just wanted to know if anyone else was experiencing that.
What engine do you have?
I have a v6 2001 that sounds like the same problem
