water pump bypass o-ring 95 camry 2.2l
1 Attachment(s)
could somebody help me out with a part number for the o-ring on the water pump bypass hose. 95 toyota camry 2.2l
I believe this is it but i'm not sure. It seems to be the right size
Victor Reinz Engine Coolant Water by Pass Gasket B45772 | eBay |
Appears to be the correct part number.
The specific P/N is sold through various vendors. Try the dealer if needing it in a harry. O-rings typically being standard size, you can measure it and check hardware, auto and hydraulic stores. |
Another question.... Does any body know the nut size(thread size) for the 2 nuts that hold he thermostat housing
Most likely 10mm dia x 1.00 pitch. It's a standard metric size. Try hardware and other stores.
