water pump bypass o-ring 95 camry 2.2l
I believe this is it but i'm not sure. It seems to be the right size
Victor Reinz Engine Coolant Water by Pass Gasket B45772 | eBay
Appears to be the correct part number.
The specific P/N is sold through various vendors. Try the dealer if needing it in a harry.
O-rings typically being standard size, you can measure it and check hardware, auto and hydraulic stores.
