what should i do?
what should i do?
i have a 97 camry 4cyl. i wanted to get an engine swap for it since my current engine could only go so far. i was thinking 1mz at first turbo charged or the 2jz (if it is possible) but i dont know how its going to work since the 2jz is rwd. or should i just get a new car.. can anyone help me?
RE: what should i do?
Turbocharging a Camry 5S-FE is very feasible and has been done many times. Years ago a bolt-on turbo kit was being sold by a Toyota dealer.
The 1MZ-FE was a factory option and will drop in but you will need to change a lot of parts (all bolt-on parts). If going this route find a wrecked V6 donor car to pick off all the parts needed.
Would stay away from dropping in other engines such as the 2JZ. Too much money and time!
thanks. i dont think im going to stick to the 5s-fe since i wanted to also get a transmission swap. and since the engine is out might as well put in a new one =] but the 1mz seems pretty quick. i really want a rwd but i guess that's not going to be an option.
Amekaji87
12-04-2011 02:39 PM
