when to change the coolant
I have a 2009 4 cyl. Camry I got in 2008 and it has about 60k on it. I think the owner's manual says to change this extended life coolant at 100k but it's over 5 years old now.
Should I go ahead and change it or wait till I get to 100k? |
yes change it now with the extended life coolant
then decide years /km used and decide next change ok these motors need protection from corrosion and heat |
where to buy replacement coolant
Thanks for the tip. I'll go ahead and change it out.
I assume I should only purchase the extended life coolant directly from the dealer, right? |
looks like you dont have to go to toyota but if its closer and the price suits you
just did a quick online search in usa .. "extended life coolant supplier " do a quick search yourself we can buy it off the shelf at most auto supply shops in australia its more expensive than most regular coolants |
