03 Camry Maintenance ?
I'm taking my wifes 03 Camry in to change the serpentine belt this weekend. She has 98K on the car and I'm wondering what other maintenance I should have done. Should I have all the belts changed at once?
I've seen this link: http://smg.toyotapartsandservice.com/index.php and have looked at every service interval and surprisingly I never once saw a mention of changing the transmission fluid. I saw check transmission, but not change. Is this something we should do now. Also, it mentions the air conditioning filter to be changed often. What is this? Are they referring to the cabin air filter? Is a coolant flush necessary? I've looked at the coolant and it's still bright red. Up until this point we've just done regular oil changes and tire rotations. Thanks, Richard |
Nobody?
I could obviously ask the stealership, but I would assume they would recommend to change everything so they can make some more $$$. Another post mentioned something about a sealed transmission so they might not have change there ATF ever, how would I know if I have that or do all camry's have that? |
