08 camry ac wont work
08 Camry Hybrid. Checked for freon. Good. Control panel works. A/C light comes on. Compressor not responding. Tried to check fuse in engine compartment. Could not take it out. Any suggestions. Hopefully I dont need a new compressor. Please advise. Thank you
No cold air?
Does the heater blower work? Did you check the A/C fuse? Auto or manual control? |
(Post 97305)
No cold air?
Does the heater blower work? Did you check the A/C fuse? Auto or manual control? Took vehicle to independent mech. He told me it was leaking evaporator. Charged system for me pending reports. Took it to dealer as I also wanted to see if shinny dashboard qualifies for replacement. It did. They tested it and told me no leaks. Vehicle with them for couple days to see if freon leaks. |
Thanks for posting back.
Great job! Suggest determining 100% if the evaporator is leaking or not! Thought replacing the evaporator required removing the complete dash to access the unit the evaporator is installed in. If leaking check on this. If leaking and the dealer is removing/replacing the dash due to warranty. They could then also access and replace the evaporator at that time. You would save a GOOD deal of money on labor costs to remove the dash. Plus make the dealer happy as they could make some money charging you for the A/C repairs. If they replace the evaporator, have them install a new expansion valve which is bolted to the evaporator as insurance against future issues. |
Thanks for your rec again. 1st estimate was $2500. Independent was $1685. Out of town dealer $1395. Checked twice. Removing dash was a small repair per dealer $150 labor at most. Evaporator requires removal of whole dashboard unit. Chaninging valve was also rec. Dealer told me they put dye and pressurized system. NO LEAKS. Now I am going to hope it stays put. Replaced transmission fluid. I thought it was drain and fill. He told me it does have a screen. Dropped pan under inverter. $248. Rear arm left wheel assembly hub. Ordered one from autozone. Delay will replace with autozone warranting part. I could do it myself but don't have time. So so far happy with this car. Trying to maintain vs get new or used one. Change oil every 5k miles. |
Not all of the dash needs replacing for Toyota repair?
Good news on A/C leaks. Replacing trans fluid is good idea to prolong life! Cheap insurance. Can be best to stick with known quantity. Used cars can have problems. New cars are expensive with added costs of taxes, license fee increase, higher insurance. |
(Post 97485)
Good news on A/C leaks. Replacing trans fluid is good idea to prolong life! Cheap insurance. Can be best to stick with known quantity. Used cars can have problems. New cars are expensive with added costs of taxes, license fee increase, higher insurance. Will keep u posted on repairs. Thanks for supporting transmission fluid change. I checked and most searches showed it only as drain and fill. Seems it is more than that. |
Thanks for the update.
