1985 Power Window Issues
Hi guy!
I have a 1985 Camry. Both power windows on the driver's of the car work, but neither of the power windows on the passenger side work. I've checked all the wiring, I've checked all the fuses and relays. Now i know for a fact that none of the windows in this model will roll down unless the driver's MASTER control switch panel is plugged in. It seems to me, that to have both the front and rear power windows go out and only on the passenger side at the same time, it'd have to be a fuse/relay or a wiring problem. However, I've checked all that and it's good to go. Now for the tricky part... all the wiring for each door is done through one cable per door (i.e. windows and lock) however the power locks are still getting power on that side and functioning. Anyone have ANY ideas what this problem might be? I was thinking perhaps the master switches on the driver's panel might be broken, but they seem ok and again, for BOTH of those switches to stop working at the same time seems odd... any help would be MUCH appreciated! -Thanks! |
Check wire loom in DS door for broken wire as opening/closing door tends to break these wires over time - especially on an 85. You could provide separate power supply to each window switch and see if they operate.
