1989 Camry LE
Ok so i got a 1989 Toyota Camry LE, the power windows dont work on the car, i cant find the fuses for them so i cant cheak to see if they are good or not. All four windows dont work but the sunroof still does. How might i go about fixing this? Also im getting a new sound system for it b/c i dont like stock speakers sooo what size are the speakers in the front and rear of the car?
thanks matt_s |
RE: 1989 Camry LE
My fusebox on my '91 Camry is under hood right next to the battery. I have replaced the window motors inside the door as those can wear out, but not likely that all 4 would stop working.
RE: 1989 Camry LE
speakers are 4 1/2 in the front and 6 3/4 in the rear.
RE: 1989 Camry LE
My 87 (similar to your 89) has a fuse box under the hood near the battery and another box in the drivers side footwell. Its a small black box to the left of where your left foot would be.
RE: 1989 Camry LE
you'll def. see your fuses when you change the speakers in the dash as you have to take off that particular lower dash panel to access the speaker.
