1990 camry brake fitting question
Old 07-21-2017, 05:14 PM
ceramicbrad's Avatar
Default 1990 camry brake fitting question
Hi. I am replacing some brake lines and noticed the "3/8-24 Inverted Flare Gold Zinc Tube Nut Fitting 3/16 Brake Line" fittings I ordered are not as long as the original ones and do not have a taper at the end of the threads(see pic).
The new ones are only 10 mm long and old ones are 15 mm. They bottom out before sealing the inside end of the joint. Anyone know where to find the 15 mm with the tapered end?
I found solution. This is it: BR170 3/8"-24 Bubble Flare Nut.......
Old 07-23-2017, 11:09 AM
Thanks for the information.
spd0544
07-23-2013 09:14 PM
Sunside Jd
10-13-2012 12:07 PM
camryss
08-19-2011 10:23 AM
sithunderbird
03-13-2008 04:40 AM
camryn00b
01-18-2007 11:39 AM
Quick Reply: 1990 camry brake fitting question
