1992 2200 runability issues
hi all,
i am doing my best to help my parents ,i did a search and did not find anything that mached the same problem 4-cyl automatic some came closebuti will try andexplane , my dad mad a left turn and the car died he restarted in and it chugged and banged and stalled coughed and sputtered and almost every time he put it in gear it would die above a out 1200 rpm it was ok , when 1 st looked at it it ran fine . i looked at it again today and it was very bad it would not idle after it was warm when it did the tach was jumping up and down and does have a slight high rpm miss. the distributor is newer, i did not find any vacuum leaks no codes in the computer .....any help please |
RE: 1992 2200 runability issues
Does it run ok in gear and driving above 1200rpm or doesn't stall andidlesabove 1200rpm but won't run in gear?
If the EGR is stuck/sticking open that is the same as a vacuum leak and the car will not idle but will run at higher rpm. Removing the EGR and cleaning, as well as the exhaust tube to it, will correct.Chack the vacuum switching valve (VSV) to the EGR as well. What type of service has this car seen? When - plugs, wires, Distr, rotor? |
it has 217,000 miles on it , been very well maintained cap was new with dist. plugs and wires ok.
it drives ok at 1500 to 2000 and up slight miss though the car does not idle well it starts off pretty normal and then misses a bit the idle comes up a bit and the falls and stumbles , you most of the time you can not put the car in to gear when its at idle . i pulled all spark plugs all dry , cleaned the filter on the egr (controler? located just to the right of the egr valve) . the problem just started in the blink of an eye the car had been running 100% fine and then ? |
Try cleaning the EGR, not just the air filter on it. Also try cleaning idle air control (IAC).
These are two easy DIYr cheap trys. Does this car have a throttle position sensor? "the problem just started in the blink of an eye the car had been running 100% fine and then ?" I don't think that's a clue. :) |
tps...yes...and seems to be working (viewed with scan tool)
replaced fuel filter , spark plugs , cleaned egr and iac,
now have a slight miss at idle and under quick acceleration it stumbles |
9 times i have typed all the details i could and hit the preview
and i get "Internet Explorer cannot display the webpage" sorry for the lack of details ...still need help well i can no longer post with out the page erroring out so if some one give me a e-mail address i will send you the details and ]maybe you can get them to post |
sorry frustrating as long as it took me to type all the details 6 times and have the
page error put this time i am doning in notepad 1st . ok i spent the afternoon working on moms car, i replaced the fuel filter and the spark plugs i cleaned the e.g.r and the i.a.c it helped the car now idles but has a slight miss but you can now put the car in gear and it is sort of driveable slow acceleration you can tell it has a miss but its mild if you stomp on the accelerator the car hesitates and then takes off like a rocket and toward upper rpm under load you can hear a whistle sound (vacuum leak?) i dont know if the car did this before i worked on it. when you push the pedal to the floor its almost like it boggs down and some times it will do a single small back fire and all is ok until you slow down and step on it hard again , still attempting to get mom and dad back on the road thank you for all your help so far |
