1992 Camry Tail Light Warning Question
OK, so I finally go around to figuring out why my tail light warning is on all the time and it turns out that my "High-mount Stop Light" was burnt, so I replaced it (bulb# 921 in case anyone is wondering). Now the strange thing is that every time I use the brakes, the tail light warning comes on again, but when I'm not pressing on it, it goes away.
Any suggestions guys? Thanks so much. |
Try jiggling the high mounted bulb around, remove and replace it.
Check the combination brake/tail light bulbs. It is possible one of the filaments in the two filament bulb has failed and has fallen onto the other filament. Check your other bulbs also. |
(Post 33789)
