1993 Steering binds a little when returning from a left turn....
Old 10-26-2016, 11:30 AM
umdaman's Avatar
Question 1993 Steering binds a little when returning from a left turn....
Wondering if anyone has any ideas what part is failing.. When I turn left at normal speeds, on the return about 1/4 before returning to center, its gets stiff and I have to move the steering wheel harder then normal. The best I can describe is as if there was a LUMP. Now if I go slow on the left turn it will be fine. So for sure it has something to do with more pressure applied to the wheels during a turn. I did a quick examine of both sides but could not really find anything loose. The only thing I found was on the right side I need a new stabilizer bar link, one of the boots has been blown open and the ball is all rusty. Just wondering if anyone had a similar issue and knows what part has likely starting to fail...
Old 10-26-2016, 03:24 PM
dirty hands's Avatar
cant be certain
upper strut bearing
ball joints
possible worn steering rack
CV joints
Attached Thumbnails 1993 Steering binds a little when returning from a left turn....-8498222.gif   1993 Steering binds a little when returning from a left turn....-8498250.gif   1993 Steering binds a little when returning from a left turn....-1993-toyota-camry-1.jpg
Old 10-30-2016, 03:09 AM
53burb's Avatar
This sounds like to me that the axle shafts need to be replaced. My '95 Camry had trouble with the steering similar to what you described before I changed my axleshafts out.
Old 10-31-2016, 02:48 PM
umdaman's Avatar
Hmmm I did have both CV Axles replaced in Dec 2010. So hopefully they have not failed. Would hope I would get more than 83,000 miles. Originals lasted 147,000 and actually had no issues but I had them replaced due to the boots failed. I'm going to see if I can mount my camera under and see if I can see anything moving in ways it shouldn't.
Old 10-31-2016, 11:02 PM
53burb's Avatar
keep us updated...
cpthomp
10-25-2011 07:05 PM
nebulakd
05-22-2011 09:30 PM
schleprock
05-19-2011 01:13 PM
94camguy
06-03-2008 09:23 AM
Quick Reply: 1993 Steering binds a little when returning from a left turn....
