1995 Camry LE Brake Line Leak
I've developed a rustout leak in my brake line just below the rear of
drivers door. I've traced the line to replace it and I can't believe that there doesn't seem to be any unions from the front to the back of this Camry... Has ABS by the way.... Question 1. Does someone know the size of this line so I can pick some fittings up early tomorrow AM prior to starting this project. Question 2. Am I being foolish if I find a decent section to do a splice from the front of the car as well as a splice at the rear of the car where the line appears to be intact. Please note, if you've been where I am, the routing of this line is nothing less than a small nightmare if you are familiar with this vehicle. OK, one more. Is there any chance of finding some illustrations on this routing, because I'll be dammed if I can find a union here besides the connections at the ABS, Master Cylinder, and where the steel line meets the rear brake hoses. Regards as always, Kevin kevusaborn@yahoo.com Chestnut Ridge, NY |
You can probably find off the shelf brake line and fittings that will replace the rusted part. Is the rusted area a straight run or bent. Brake line can be bent to fit. You will need a flare tool and threaded couplings. The Toyo line may be metric but you can probably get close enough with stock line.
Thanks for the reply Pedro,
Ok, In short here's what I did, cut out 5 inches of line at which happened to be at the rear end of the plastic shroud that "protects this line", 4 unions and roughly 6 flares later, the new line is in..with a slight bend which was needed to adapt the two connections. I guess the most difficult part of this procedure was to flare lines that I really couldn't mess with too much or I would have caused kinks, leaks etc. Strange part was, this area replaced was rusted through and the rest of the lines were solid on overall with outside rust to some degree.. I gather it was from the plastic shroud holding frozen snow, ice and salt, which actually did the corrosion here.. We're up and running again, I know down the road, these lines will become an issue but I'll worry about it then..... Have a nice Memorial Day and don't forget those we remember on this day. The people that fought for this great nation. Kevin |
