1997 camry no dash lights a/c fan no windows
Hey I have just brought a 1997 camry well driving it home I noticed all the dash lights has turned off as well as the radiator fan the windows had also lost power any help regarding this would be greatly appreciated thankyou
No dash lights glove box light doesn't work don't know if it ever did no lights on shift lever the tail lights as well as the front lights blink and then turn off and the fan turns on with ac also the electric windows have stopped working thanks for the reply
If front lights are blinking when AC or windows are working there may be a problem with the wiring, battery, connections at the battery, or alternator output.
The issue may be the power to the lights and other systems is weak. The extra load of the AC or windows now causes a further drop in voltage.
Check the battery for full charge, alt is charging OR, battery cables and connections to battery are OK, battery ground cable connection.
lemmon_water
07-01-2015 05:18 AM
Mark61
05-18-2009 08:34 PM
