1MZ-FE engine has no power
i have a 94 toyota camry v6 le coupe with a 1MZ-FE engine. when i press the accelerator i get barely any power. i can only reach 2200 rpm. the car will only go into drive or park. the engine is getting fuel so i assume its an airflow problem but i am totally lost.
Only go in drive or park?
If airflow have you check the air filter and engine intake hose? |
i changed the intake hose and filter. the hose had a split in it about a year ago.
well, if trannie is bust, ECM might as well put engine into so called "limp mode" to prevent trannie from further destruction. Which is just that - just enough to get you place safe.
You can rev the engine higher in Park or Neutral?
May still be a fuel issue. A badly plugged fuel filter (rare but happens) or failing fuel pump can cause the engine to rev OK in P or N but barely have enough power to make it over the curb onto the driveway. |
