2001 Camry back seat removal
Just wondering if somebody knows how I can remove the back seat of my Camry?? I tried lifting the seat like what you do in most cars but it wouldn't move. Ideas appreciated. Thanks.
RE: 2001 Camry back seat removal
check along the bottom of the front edge of the seat..my nonner has these tabs that you pull that unlock the bottom part of the seat, and the back part should be bolted in.
RE:1995 lowering height
G,DAY, I WAS WONDERING IF ANYONE KNOWS HOW FAR A 1995 GEN3 COULD BE LOWERED? IVE GOT 17"+7" RIMS WEARING 215/35 TYRES
RE: RE:1995 lowering height
honestly, it depends on how much clearance you have...youd almost have to try the springs and buy tires around them
I have a '99 camry and have had the seat out of it a few times. There are 2 clips holding the seat in place. When you sit in either side of the back seat, reach under the cushion between your knees. You can feel where the clips are. Wedge your fingers under the cushion, and pull straight up with a good amount of force until the clip snaps loose. Repeat the procedure on the other side.
