2001 Camry Blower Noise
Old 04-20-2009, 11:24 AM
louisphelpsjr's Avatar
Default 2001 Camry Blower Noise
I have a 2001 Camry that in the last 3 days has started making a thumping sound when the fan is set at the higher speeds. Also, at the lower speeds, there is no noise but no air flow as well. At the higher speeds, along with the thumping sounds, I do get a little air flow. From reading other posts/replies, the blower resistor seems to be the first place to look but I have not read any other posts that have combined the thumping noise along with no air flow at the lower speeds. Is there anything else I need to look at? Thanks in advance for the assist.
Old 04-21-2009, 12:56 PM
A bad blower resistor would result in high speed only operation.
The blower/motor is held in by 3 screws and easy enough to drop out and inspect the blower cage.
Old 04-24-2009, 05:57 AM
Well, it turned out to be something entirely different. Something, I assume a field mouse had made nest in the blower fan. On lower speeds, there was no air flow because the fan was so clogged that it could not push any air and the thumping noise at the higher speeds was probably due to the weight of the nest not letting the fan spin evenly. I had already pulled the blower resistor and checked it out and found no obvious problems but replaced it with the new one I had purchased since I already had everything tore down anyway. After cleaning out the fan and putting it all back together, it runs like a champ. Thanks for the assist.
greyghost
08-27-2011 05:16 PM
carNewbie
01-15-2010 09:18 PM
red73mustang
07-12-2009 09:21 PM
Bimmerknut
02-21-2008 11:44 AM
dwurzel
08-05-2007 03:52 PM
Quick Reply: 2001 Camry Blower Noise
