2002 Camry Idle speed help
I just changed my water pump on my 2002 Toyota Camry 4 cyl. When I restarted the car, the idle speed is very low to point of the car almost shutting off. I read that this can happen when the negative battery cable is disconnected and the car's computer needs to relearn the idle speed. Help from anyone?
The computer via a electric throttle motor sets the idle. If typical of Camry the idle will fix itself after several restarts, know of no short cuts
