2002 sportivo gen 5 timing belt or chain?
Hi guys, i've heard mixed answers from all over the web about whether or not the 2002 toyota camry sportivo gen 5, 4cl 2.4l, 2AZ-FE engine has a timing belt or chain? I've heard only the v6 engine models for the fifth gen had belts and the vvt-i 4cl models had a timing chain. Urgently need an answer as i've hit 155,000kms and i need to know if i should be dreading the price of a timing belt kit + water pump or not :confused:
if the 2AZ-FE engine links are correct ...double cam chain timing shimmed valves
https://www.camryforums.com/forum/di...-2014-a-50782/ |
thanks man! from ipswich as well yeah? what model do you drive?
brassall
the toyota camry I had a few years ago was a earlier wide body 4 cyl auto till the engine cooling fan failed in traffic on the western freeway and popped the head bolt threads had to buy a replacement vehicle the same week and no camry was available still have a strong interest in toyotas |
