2005 Camry abs code 39?
I have a 2009 Camry that has the abs light on, I found how to read out the code online and it blinks out a 39. None of the sites seem to say what 39 is, I found one site that said it could be a left wheel sensor, so I changed it this afternoon, but the code will not clear. Does anyone know what a code 39 is? Thank you for the help!!
Left rear speed sensor or sensor circuit.
Make sure the sensor is installed correctly. Resistance between sensor terminals should be less then 2.2K ohm. Resistance between each sensor terminal and body should be 10K ohm or greater. Clear codes by connecting terminals TC and CG then turn on ign switch. |
so I crawled under the car and checked, the ohm reading for the sensor was 1.1k between terminals (and 1.2k on the one I replaced :eek: ) I couldn't get a reading to the body since the new one is installed and the paint didn't want to scrape down to metal through the small opening. My guess is it is fine considering it is new. I also followed the wire from the sensor to where the connector is under the rear seat, that connection was fine, after that it goes into the harness, I am guessing it comes out at the abs control under the hood, but none of the wires are easily visible in there. Is there somewhere else I can check? I need an inspection sticker and the car won't pass with the abs light on, the garage wants big money as they say chasing down electrical bugs is time consuming. As a note the car is a 2005 not a 2009, I put the correct year in the title but not in the body.
See private message.
