2006 Camry Cabin Filter
I'm trying to find out were the Cabin Filter (also known as the A/C/ Filter) is located and if it is something I can remove/replace when needed.
IF it is something I can do then what do you clean it with? Thanks Russell :D |
RE: 2006 Camry Cabin Filter
You'll find it behind the glovebox. You'll need to lower the glovebox have easier access to it. It's a replacable HEPA filter that cannot be cleaned. Good Luck!
Joel, CA |
behind your glove box. be sure to take the shock loose on the side of the glove box when you are replacing it.
Use a Hanes Manual, you wont regret it.
