2007 Camry passenger side power door lock
The passenger side door lock isn't working. Anyone know what amp fuse and location (under dash or hood)? The previous owners took the horn fuse out. God only knows which other ones they did this to. Thanks!
Does either the individual or master door lock switches work?
The system uses a computer connected to the following fuses: Door No 1 Door No 2 ECU-B ECU-IG ECU-ACC Would assume if one door lock is working power is getting to the system thus look at the individual lock or switch. |
It works all of a sudden. Yesterday, it didn't work at all yesterday. :confused: Thank you for the reply. ;)
s this a alternator or Voltage Regulator issue?
