2008 camry air conditioner issue
hi guys im new to this forum.. never owned a camry before and i like it alot..
my issue is this.. the ac.. it cools fine.. but the fan doesnt seem to be strong enough.. on a hot day. it cools maybe the front seats but doesnt seem to make it to the back,.. even when its cranked up all the way. again it cools.. just seems like the fan is pretty week.. any of you experience this issue? any fixes??? any help is appreciated thanks |
Is the fan weak or the AC not cooling the air?
ac cools fine.. but fan is weak and doesnt cool the car properly on a hot day
Try to determine if an air duct is partially closed by a non-working air control door.
Is the climate system manual or automatic? |
2008, aye? they have weird Denso climate control units; as in - they have mind of their own. Engineers came up with some funny presets for them that are beyond your control. say, mine will start blowing cold air after cabin reaches preset temperature, through dashboard vents, and it's normal.
same may go to you, buddy. I have entire research on this at Toyotanation. Lawyers had their say in how to run those climate controls. now again, my 2007 will kill you with cold air if set at fan=2 position. that is true too. |
cabin air filter behind glove box is probably clogged supposed to be changed at 30K miles my 2011 only has 10,000 miles mine was full of leaves,trash pollen ect,take it out(5 minutes) beat it on a tree or use air to blow out the trash,it looks like a air filter! or replace for 30 bucks
thanks for the info.. apparently the previous owner.. lived out in the country on a dirt road and yes indeed the filter was completely clogged.. didnt even look like a filter anymore..replaced it and its fixed now... .. i appreciate all the help :)
