2009 Camry 2.4 P0300, P0302, P0303 P
My wife 2009 Camry 2.4 runs great 99% of the time, but sometime it barely runs. I seems like that when it is shut off and restarted it runs fine. It sets the following codes. P0300, P0302, P0303P. I have installed new spark plugs. I switched coil pack #2 & #1 and #3 & #4. It still sets the same codes. I have a hard time thinking the #2 and #3 fuel injectors started acting up at the same time. It is hard to test when it runs good 99% of the time.
What else could be causing those codes?
I appreciate any help.
The check engine light was flashing when my wife was trying to get home. I have drove it on short drives only to get the light to turn on. The light has turned on for me but it has not flashed. My code reader is a basic one and only gives the codes. I have a better one(I hope) ordered and should be here Monday.
Thanks
Thanks
Don't have an answer for you on the PCV.
Maybe when you get the scan tool and start looking at engine parameters it will tell us more.
Question: when you examine the plugs from misfiring cylinder do they appear much different from the other plugs?
Can you reproduce the misfire by wiggling/tapping the coil or injector connector/wiring?
Have you disconnected/reconnected injector connector on the off chance doesn't have a good fit?
The old spark plugs looked good, but the #3 plug had a small brown spot on the white electrode. Other than the small brown spot it looked good.
The connectors on the coils are good. I have not unplugged the injectors but I made sure they were connected.
Last night It missed at starting and it ran fine after that. It did not set a code.
Thanks
Thanks
This is the test results I got from my new scanner.
Thanks
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Test report:
MID:$01 TID:$8e
- O2 Bank 1 Sensor 1
Test incomplete or dependant test failed
MID:$01 TID:$91
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
MID:$02 TID:$8b
MID:$02 TID:$8d
MID:$02 TID:$8f
MID:$21 TID:$a9
- Catalyst Monitor Bank 1
MID:$3d TID:$c9
- EVAP Monitor (0.020")
MID:$3d TID:$ca
MID:$3d TID:$cb
MID:$3d TID:$cd
MID:$3d TID:$ce
MID:$3d TID:$cf
MID:$3d TID:$d0
MID:$42 TID:$91
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 32,164mOhm Min: 0mOhm
Test result value: 21,881mOhm
PASS
MID:$a1 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Monitor General Data
Max: 65,535Count Min: 0Count
Test result value: 24Count
PASS
MID:$a1 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Monitor General Data
Test result value: 0Count
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Test result value: 8Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 16Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
End of report.
Thanks
Test report:
MID:$01 TID:$8e
MID:$01 TID:$91
MID:$02 TID:$07
MID:$02 TID:$08
MID:$02 TID:$8b
MID:$02 TID:$8d
MID:$02 TID:$8f
MID:$21 TID:$a9
MID:$3d TID:$c9
MID:$3d TID:$ca
MID:$3d TID:$cb
MID:$3d TID:$cd
MID:$3d TID:$ce
MID:$3d TID:$cf
MID:$3d TID:$d0
MID:$42 TID:$91
PASS
MID:$a1 TID:$0b
PASS
MID:$a1 TID:$0c
PASS
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
End of report.
