2009 Camry XLE Questions: Tire Pressure, Oil, Blue Tooth
I have a 2009 Toyota Camry XLE. Please help me with the following...
1. How do I check the tire pressures with the digital controls from inside the car? 2. How do I check the oil level with digital controls from inside the car? 3. How do you change the volume and ringtone of the Blue Tooth phone feature? I'd greatly appreciate step by step instructions. Thank you! |
1. The tire pressure system doesn't have a readout for actual pressure.
2. The oil levels don't have gauges. 3. Info should be in the owners manual. |
(Post 90313)
2. The oil levels don't have gauges. 3. Info should be in the owners manual. Thanks for the response. Just want to make sure I'm clear though... For the tire pressures and the oil level, the only alert I'll get is if they're low and I can't actually check them inside the car's info display, correct? As for changing the car's Blue Tooth volume and ringtone, I've looked at the owner's manual and still can't find anything. |
The tire pressure is an alert that one tire pressure has dropped enough to set off the alert.
There is no oil level alert, this is a low oil pressure alert. For the ringer volume, when the phone is ringing reduce volume with steering volume control. For the ringtone, go to the phone icon, then select ring tone and select one. |
