2011 Camry LE slip indicator
Hello.
Recently the Slip Indicator light has come on. With it the Check Engine light as well. I did see somewhere that the two might be associated. I borrowed a code checker, and the three codes that it indicated in both Stored and Pending did not seem related to Skid, or speed sensors, or whatever else is involved. Codes were P0171 P0441 P0455. Are there additional codes stored that I may be able to access to help me out a bit ? I didnt see anything like that on the code reader, but have not used one of these things before. I never like just leaving myself at the mercy of a repair shop. Thank you for any help. |
Check evaporative purge valve.
Get the code P0441 code fixed. The other codes plus Slip Indicator light should go away. |
