2012 camry not turning off??
So last night my car wouldnt turn off. Took the key out and still on.
this morning i remived a 7.5v fuse under the steering and it turned off i put a different driver seat in but its from another 2012camry |
Anyone???
Originally Posted by 2012tcamry
(Post 108988)
Originally Posted by cj1
(Post 108997)
Engine still running after key removed?
Do you have test light or multimeter to test with?
In addition see Alldata or Mitchel for wiring schematic. Need to test to see if ignition switch is the faulty or not. |
(Post 109016)
In addition see Alldata or Mitchel for wiring schematic. Need to test to see if ignition switch is the faulty or not. i took out a 7.5 fuse under steering wheel it turns off but the battery still drains |
Look for the IG1 relay under dash drivers side junction box. Pull relay see if stops battery drain.
Which fuse it? The cover for the fuse box is missing
(Post 109019)
Se Alldata.com or Mitchell for power/relay/fuse box identifications. |
