87 Camry question About strange Clutch problem
Hello to all,
I have a 87 Camry 2.0 5 speed and the clutch plate was worn too low (long story). So I had the whole kit i.e. clutch, plate, and everything else that comes in kit replaced. The car ran fine for a while (about 7 months) then one day after driving a long time the clutch would not come out of gear. After forcing it out of gear it would then would not go back into any gear. If I would force it into a gear it then would have extreme problems going out of gear. So I went back to the mechanic who installed the clutch and he sent me to a neighbor mechanic who installed a entire NEW clutch and kit again. In the end the mechanic did not say what happened or what caused this but they were mad at each other. So I am guessing here that perhaps some bolt or something was not tightened down or done correctly causing the job to be redone again. My ? is what would cause this to happen (described above about not coming out or going into gear)? Next ? is when you are doing the job of installing a whole clutch kit are there some sensitive bolts/areas that if not done correctly would cause serious problems in the future such as what happened to me? Please advise me here thanks so much for your help in this matter. I am sure someone on here knows and has had a similar experience please share. Dave |
RE: Default 87 Camry question About strange Clutch problem Hello to all, I have a 87
HI ! buddy actually you just go near showroom they can solve your problem actually i know this problem is so curious but they can be solve same problem has come my friend car BMW 328i but they problem has solve because they had gave to showroom .
BPA bpa bpa bpa
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system accessories for replacement, such as Fuel injection Nozzle, Plunger and Delivery valve, ETC In south of china . for more detail please visit our website : www.yellowstonediesel.com www.dieselinjection.cn Yellow stone diesel parts plant was founded in 1997.Over the years, Yellow stone has grown and gained a reputation for producing high quality products and delivering them on time. 105015-5860 105015-5860 105015-5940 0 433 171 134 0 433 171 137 0 433 171 146 5611065 H60S30A538 5611650 BDL110S6133 5611735 BDL110S6267 6801082 6801082 6801087 6801087 6801088 6801088 DN10PDN130 DN0PDN121 HL176S27D525P2 2418455518 2455-518 2418455714 2455-714 9401087506 9087-506 134151-4120 P121 134151-4920 P129 134151-6420 P143 NOZZLE DENSO 093400-7690 DN10PDN129 NOZZLE DENSO 093400-7700 DN10PDN130 NOZZLE DENSO 093400-8220 DN0PDN121 131110-9320 131110-9420 131160-0320 |
