91 camry brake and battery lights on
The other night the battery and brake lights came on. Took the car to autozone the next day, had them test my battery. They said it was a bad battery so I purchased a new one. |
What engine 4 or 6 cylinder?
Did the problems go away for a time after the new battery? If having a volt meter, check battery voltage after the car has sat for approx 30 minutes. A fully charged battery is 12.6v. If possible start engine and check battery voltage at 2000 RPM. Should be 13.9 to 15.1v if engine cold. Approx 13.5 to 14.3v if engine warm. What is the first letter/number of your VIN? J = Japan built 2 = Canada |
