92 Camry door lock problem
Old 03-17-2016, 02:05 AM
Ferrance's Avatar
Unhappy 92 Camry door lock problem
Master switch will lock all doors but will not unlock them. I've installed a new master lock switch, new 40 amp fuse behind passenger kick panel but problem persists.
Any suggestions?
Old 03-18-2016, 12:39 AM
Check the wire harness in the door jamb. Your car is fairly aged and the wires could have become damaged through all the opening and shutting of the door.
Old 03-22-2016, 11:45 PM
wdc123's Avatar
You can look for a similar issue I had on this forum. The right rear door window had open and close issues as I remember. At the end figured out as said above it was the door jamb harness from years of opening and closing. This door was where the baby car seat was and open and closed a lot. Soldered and reinstalled.
DoverTim
02-16-2012 08:29 AM
ftamasi
09-07-2011 07:39 PM
digiadv
03-25-2011 04:47 PM
toyoman1985
07-26-2009 12:31 PM
T.K.
03-29-2009 03:31 PM
Quick Reply: 92 Camry door lock problem
