93 camry stalls
My 93 camry stalled today as I pulled into my parking spot. I had to back up to realign the car and then pull into spot. It kind of sput sput when I back up and then sput sput and then died.Started car up and it ran and did not stall. I then took the car out later. Drove it for about 5 miles. Turned into a driveway to turn around. It stalled when I stopped the car in the driveway. Car started right up again. Went to parallell park the car, tried to stall in reverse, but I put had my foot on brake and revved the engine. Parked car. Left about 50 min later and went home. Pulled into my parking garage which requires a slow right turn to get into. Pull into spot, back up, parked car, let idle, it stalled. Started car back up and it idled without stalling. This only happened today. The only thing I have done different is I was desperate for gas and put Citgo gas in the car. It is the only thing I have done different
RE: 93 camry stalls
I doubt the gas unless there was water in it, a little "dry gas" additive might help. Clean IAC first (do search). If that doesn't clear problem I'd remove EGR and clean it. Also look for vacuum leak in one of the vacuum hoses. All simple stuff you can do yourself.
RE: 93 camry stalls
I will give that a try. Thanks
