93 Camry V6 thermostat replacement location?
Help! I am having issues locating where to replace my thermostat on my 93 V6 Camry. I have been told like 3 different things. Can someone please help me and if possible please post some pics of the locationwhere the thermostat is located. Thanks in advance for any help!
RE: 93 Camry V6 thermostat replacement location?
Kinda apain in the arse. To make it easy follow the drivers side of radiator hose. Remove air filter box and snorkle and remove 6mm(10mm hex socket) remove houling and t-state, install new statt and gasket being sure statt stays in place and reverse removal. Fill with coolant after removing a heater hose at the heater valve. Once the coolant starts to come out 0f the heater hose install hose and tighten. Start engine wait till statt opens with heater valve open heater fan off and ou are done.
