'93 XLE Camry engine
My radiator's busted, so I'm in the process of getting one, but I don't know what liters my engine is, can you help?
I have a 1993 Camry XLE. The engine says "V6 FOUR CAM 24" and another part says "3000." Sorry, not very knowledgeable at cars. Is this enough information to know what liters my engine is? I searched for possible radiators, and they're either compatible to 2.0L, 2.2L, or 3.0L engines.... not sure which one mine would be. Thanks! |
The engine displacement is a little less then 3 liters hence the 3000 on the engine.
It might be a 3VZ-FE model. The 2.0L and 2.2L engines were 4 cylinders. See link below: http://www.rockauto.com/catalog/x,ca...,parttype,2172 |
thanks, toyo!
sorry, im alittle confused as to what you said, so the radiator i should go for is the 3.0L Engine compatible? and the catalog that you linked, are they all 3.0L compatible? |
Yes, with an explanation.
Over the years the Toyota Camry used two different model V6 engines both having 3.0 liters of displacement. These were the 3VZ-FE (appears to have been used from 1992-93) and the 1MZ-FE (1994 to around 2007). Thus you must be specific as to which year of Camry you have. The radiator seller should be able to determine the right part by the year of Camry and engine type, a 3.0L V6. Given the year assume the model type is 3VZ-FE. The link has radiators listed for a 1993 Camry with 3.0L V6 engine. There is only one V6 engine listed for this model year, this being the 3VZ-FE. |
